S22 display getting faded from camera and top left side
(Topic created on: 07-10-2024 09:57 PM)
Shuvendu814
I am using s22 from 7 months ago. After purchasing the device, in after several days, I have noticed one feded circle around camera cut out.
Now few days ago, I have noticed the screen getting feded from top left corner same like camera cutout. This only visible when some dim light content playing or when brightness is low.
Kindly help me what to do or this problem happens to anyone suggest me what to do now.
Thanks.
2 Comments
NOMAĐ
It's the light bleed I guess. Mine also had a bright light around the camera when used under dark areas.
cs_member10
Dear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
Kindly restart your device once: To power off through Quick settings, swipe down from the top of the screen. Tap the Power icon in the upper right of the screen (next to the Settings icon), and then tap Power off.
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
If the issue still occurs, please visit the service center for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
