S22 Ultra. Not going in sleep mode when idle / battery drain over night
(Topic created on: 10-26-2022 02:33 PM)
Yaasar
My samsung galaxy s222 ultra is loosing battery overnight. It seems it is not going into sleep mode even when its locked. I was hoping that this will resolved post oneui 5 updation but the problem remain same.
S22 ultra Phone is draining battery on idle mode in the same ways as it is being used
7 Comments
Yaasar
Here are the screenshotScreenshot_20221026_142507_Device care_1000002465_1666774507.jpgScreenshot_20221026_142512_Device care_1000002466_1666774512.jpgScreenshot_20221026_142503_Device care_1000002464_1666774503.jpgScreenshot_20221026_143516_GSam Battery Monitor_1000002467_1666775116.jpg
Sid_Karna
Try uninstalling that battery checking app.
Shashank_R270
Did you face this problem initially when you purchased S22 Ultra?
Yaasar
No
Shashank_R270
Then it's due to a update,wait for the next update,then might your problem be solved.
NOOB_1ST_ACC
Do factory data reset after next update and also add apps to deep sleep. Only add that apps that apps notifications should not come until you open that and that app will not run in background and adding apps in deep sleep saves a lot battery during overnight also.
I had faced overnight battery draining issue 5-10% every night but after adding apps to deep sleep rarely 1 or 2 % draining
Yaasar
Already submitted multiple times and there is no response from your side. Stop copy pasting the same answer everywhere
