S22 Ultra Network Reception Problem
(Topic created on: 07-15-2022 12:00 AM)
VISWA_BOLLOJU
Guys are you facing any issue like sudden stoppage of Mobile data while you are streaming YouTube and Other apps. I have facing this issue while streaming YouTube even though the mobile data is active. It's like it stops suddenly even the mobile data is active and YouTube just buffers thier after. I have to turn on the Airplane mode then switch it off, so it will work well after that...!. If you persist this issue comment please
10 Comments
Gst26
See Presently this is not so with my S22ULTRA..It might also be your Network issue, Does it happens at specific location or Everywhere?? have you checked the Data Speed of your Network just immediately when such issue occurs (At least 3mbps Speed required for YouTube Streaming)..
VISWA_BOLLOJU
It works fine but suddenly the download sign (Both up and down sign) will stop and only uploading sign would on. So i switch on the Airplane mode and after that it is fixed. Speaking about location the sign i get is full bars. Network speed will be above 25Mbps at my locality
Gst26
Reset Network Settings & initiate for Both Sims if one out of them is of Jio (Since in many cases jio disturbs other Sim network also Specially when you using Jio in 2nd Slot & using data from 1st one) & Restarts after that..And check if issue resolved or not...Screenshot_20220715-005635_Settings.jpgScreenshot_20220715-005649_Settings.jpg
VISWA_BOLLOJU
Will do and if any changes do occur I'll reply
Roshan5
Expert Level 3
I was facing with Airtel, Vi Sim Card in S22 Ultra and in S21 Ultra. I have to turn on and off Flight Mode to reconnect Internet. At present i an using Jio Sim and no issue
VISWA_BOLLOJU
Maybe try resetting the network settings. I did this, after that I didn't encounter with any issues rather than buffer while streaming
Roshan5
Expert Level 3
I have already tried Factory reset in S21 Ultra and S22 Ultra but Problem not solves. Only working Jio Sim properly in My Phone for data internet.
. In Past Already Sell S21 Ultra and immediately buy New S21 Ultra but in new S21 Ultra Airtel and Vi Data Internet was not Stable
shakti
This problem is not mobile because it is a network provider, I am using galaxy s series for a long time and this is a big problem in both networks.
Roshan5
Expert Level 3
But same sim cards working properly in othe devices for Data Internet.
