S22 Ultra Display Issues
(Topic created on: 07-02-2023 12:33 AM)
Sam3
My Samsung Galaxy S22 ultra screen bleeding massively!! Phone have not fallen down.
 What should I do now??
 Please help.....
Sam3
One of customers representatives suggesting me to reseting my device. Will it help me to get rid of this problem?
Karan087
You can do that but again chances of fix are low.
Sam3
that's mean you are saying screen flickering issue will coming again after sometime?
Karan087
Yeah it can come... better do not update your phone at all and only update google play services security update.
Sam3
I think after installing april 2023 security patch update this problem happened. Should I stay with this april update?
Karan087
Yes... it could have happened due to multiple reasons apart from software such as one image or video played for long and it remained like that only.
You can try to reset but chances of fix are low.
My is on June 2023 update an touchwood no problem.
Though I had purchased comprehensive plan when I purchased the phone.
Sam3
On my device developer option had been turned on for a long time of period. Did it caused the problem?
Karan087
No.. unless and until you did setting that you were unaware of.
Sam3
I am wonderred, I did not turn off the developer options but after this skin bleeding issue happened & I'm turned on & off my device several times then this developer option turn off automatically. how is it possible!
