S22 Ultra April Update ! Fix These Problems
(Topic created on: 04-13-2023 01:29 PM)
SG24U
Guys Finally S22 Ultra got April Huge Update i hopefully Fix fast battery drain issues
4 Comments
VISWA_BOLLOJU
Bro, are you facing any network issue (mobile data) network connectivity issue so far after the April patch.
LLCoolWas
Beginner Level 3
Yes! After the update my phone will not hold a signal in most areas.
swapan1997
Share your battery stat ..🤷🤷🤷
cs-member11
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Warm regard,
