S22 System UI not responding
(Topic created on: 03-16-2025 06:28 PM)
Tony005
Recently my phone is freezing and restarting itself very frequently. Getting theSystem UI not responding. Hope Samsung releases a software update to fix it.
#S22
5 Comments
goodthings
goodthings
Your's most welcome to here.
Jerry770
Was it after installing the February security patch? Some users faced this same issue after the February patch.
Tony005
Yes, I never faced this issue before
cs_member10
Dear Samsung Member,
1. Galaxy device freezing and performance issue: ● Check space availability: Settings > Battery and device Care > Storage.
● Check RAM in your device: Settings > Battery and device Care > Memory.
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Clear cache memory of a particular application: Settings > Apps > pick the app > Storage > Clear Cache.
● Close Background Apps.
● Remove third-party applications.
● Remove memory card: Apps > Settings > Device maintenance > Storage > More option > Storage settings > SD card > Unmount.
● Remove third-party accessories.
● Kindly disable Power saving mode( if enable).
2. Galaxy device auto restart issue: Note: Kindly use genuine Samsung charger.
1.Disable auto restart function, there are two methods to disable auto restart function:
Settings > General management > Reset > Disable Auto restart (if enabled).
If the issue has not been resolved, then follow;
2.If you are facing this issue after installing any new application, then uninstall that application:
Settings > Apps > desired app > Uninstall > OK.
3.If the issue is still not been resolved then, update software:
Go to Settings > Software update > Download and install > Checking for software update > Software update available > Tap on Download > Downloading updates > Tap on Install now
4.If the issue still persists, then reset the settings:
Go to Settings > General Management > Tap on Reset > Tap on Reset settings.
5.If the issue is still not been resolved, Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
