12-31-2024 10:41 PM in
Galaxy S- Mark as New
12-31-2024 10:44 PM (Last edited 12-31-2024 10:44 PM ) in
Galaxy SIf it works then mark my solution resolved 😊.
If doesn't then visit nearby Samsung service centre.
12-31-2024 10:45 PM in
12-31-2024 10:49 PM in
12-31-2024 10:50 PM in
01-01-2025 09:28 AM in
Galaxy SDear Samsung Member,
As per your concern, we would request you to kindly perform the following steps to resolve your issues.
● Galaxy device auto restart issue:
→ Kindly use a genuine Samsung charger.
We always recommend using a genuine Samsung charger for charging your device.
→ There are two methods to disable the auto restart function.
1- Tap on Settings> General management>Reset > Disable Auto restart (if enabled)> Auto restart disabled.
2- Tap on Settings> Battery and device care> Three dots> Automation> Auto restart at set times if enabled.
→ If you are facing this issue after installing any new application then uninstall that application.
Tap on Settings> Apps > desired app> Uninstall> Ok.
● Galaxy device Freezing and Creshing issue: ● Check space availability: Settings > Battery and device Care > Storage.
● Check RAM in your device: Settings > Battery and device Care > Memory.
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Clear cache memory of a particular application: Settings > Apps > pick the app > Storage > Clear Cache.
● Close Background Apps.
● Remove third party application.
● Remove memory card: Apps > Settings > Device maintenance > Storage > More option > Storage settings > SD card > Unmount.
● Remove third party accessories.
● Kindly disable Power saving mode( if enable).
● You can reset your device by following the steps:
3. If you do not remember, then advise to reset (Forgot password) his/her Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tab on Factory data reset to reset your device to its factory default settings. This will erase all data, including files and downloaded apps.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
05-20-2025 09:07 PM in
