S22 Battery drain very fast
(Topic created on: 05-29-2024 11:16 PM)
Rohit_S22
Samsung team kindly suggest
14 Comments
bablu03
Hai bro I m also using s22 only bro... I don't feel any fast draining in my battery performance
Kindly clear the background apps bro before u watching any movies or post bro
Rohit_S22
It's good.
What is the SOT and S Off Time
bablu03
Rohit_S22
Its showing u are charge ur phone with in 60-70 %.
Can u share after last charge?
Devel_
Well,there's nothing wrong,if you look at the big peer its says 70% percent used in 14 h 13m,which is normal,plus the title says since the last charge,so your phone is perfect normal
Rohit_S22
U mean to say this is perfect backup?
goodthings
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
Rohit_S22
This is after factory reset
goodthings
