Battery draining fast A14 5G
(Topic created on: 04-17-2025 07:04 PM)
chintalp
Battery draining fast A14 5G one 61
2 Comments
Lateroadlight
Same with m16 5g
cs_member10
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
