S22 Battery drain quickly
(Topic created on: 09-11-2023 10:40 PM)
Rohit_S22
How to increase battery backup.
13 Comments
Rajendra186
Same problem i am also facing after July patch update in my a53 5g
Rajendra186
Please help
umesh30
You can use power saving mode all the time and uninstall heavy unnecessary apps..
Put heavy apps to deep sleep mode manually.
Don't use superfast charging mode regularly.
Don't use RAM Plus.
Disable unnecessary notifications by going related app's notifications category setting...
Turn off unnecessary alarms and reminders...
Turn off auto sync, do syncing process manually if needed...
goodthings
My dear turn on power saving mode, location turn off when necessary open than close, stop adaptive brightness, stop vibration, remove unused apps also put deep sleep or sleep. Stop all background apps.Thanks.
CODM6567
Use Dark mode(if brightness >40%)
Use Dark wallpaper
Turn off adaptive brightness
Turn off quick share
Switch to light mode in performance profile
Put unused apps to deep Sleep
Turn on location services for while using apps only
AOD as Tap to show
Turn off 5g
Rohit_S22
Always use dark mode
Adaptive brightness on
Quick share off
Already puted unused app
Location off, on when required
AOD off
Off 5g
Fast charging and super fast charging off
Adaptive Power saving mode on
Vibration only on incoming call.
Ram plus off
Shared battery performance with this setting.
CODM6567
Then you have 3 options left.
1. Inspection of battery health by smart tutor app and its replacement
2. You can follow some modes and routine as shared by me
3. Upgrade your device.Screenshot_20230911_234405_Samsung Members.jpgScreenshot_20230911_234409_Samsung Members.jpgScreenshot_20230911_234412_Samsung Members.jpg
Rohit_S22
1. I have select default network setting is LTE/3G/2G
2. Power saving option is not showing in routeen
3. During call done as shared.
CODM6567
Do install smart tutor app and check for battery health
