11-15-2024 02:25 PM in
Galaxy S- Mark as New
11-15-2024 02:51 PM in
11-15-2024 03:09 PM in
11-15-2024 03:52 PM in
11-15-2024 04:26 PM in
11-15-2024 04:36 PM in
11-15-2024 06:49 PM in
11-15-2024 06:51 PM in
11-16-2024 10:27 AM in
Galaxy SDear Samsung Member,
As per your query, we request you kindly check with the other device to which you have connected through wi-fi, and check whether the internet in working properly or not on that other device.
● Forget the Network: Settings>Connections>Wi-Fi>Wi-Fi network> Tap and hold the Wi-Fi network that you're having trouble with until the menu allows you to select Forget Network.
● Reset Network Settings: Settings>General Management.>Reset>Reset Network Setting.
● Restart the Router and Mobile Device: → Switch off your Router (at the wall or with the power button on the router) and wait for 2-3 minutes before switching it on. While you're waiting, press the Power button on your mobile device and select Restart.
→Once the router has been successfully connected to the internet again, try to connect to your network on your mobile device.
→ Make sure there is no interference between the router and your mobile device. Concrete walls, fridges, and microwaves can all interrupt the Wi-Fi signal.
● Disable flight mode:→ Kindly check and disable the Airplane/Flight Mode on your device.
→Check Flight Mode by swiping down notification panel on your device with two fingers to access all of the Quick Settings.
→Find the Airplane/Flight mode option and turn it off.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
