S21 fe battery drain
(Topic created on: 07-14-2024 11:30 PM)
ansarijawwad007
S21 fe after one ui 6.0 update draining battery too fast when 5g in use.
Getting on 4 hour of screen time in one full charge
Samsung should check the issue and remove the issue
4 Comments
Sameer
S21 FE battery is weak ...we can try to improve it with the following tips and tricks ...
Please refer to the below link...
to enhance battery life
https://youtu.be/DXM7pdW5a-w?si=MyzIiShLX03FRGL2
Also make your phone run 2x faster
https://youtu.be/pgNi1Pmua3c?si=IIBb6EDnMn4KM71g
cs_member10
Dear Samsung Member,
As per your concern, we want to inform you that while using 5g networks due to higher power consumption causes the mobile phone to heat, and if the phone is connected to multiple networks at the same time, the battery may drain faster, and the phone heats more than usual.
If you are facing more draining as compared to normal, kindly perform the following steps by the given links to resolve your issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
goodthings
goodthings
Your's most welcome to here.
