S21 fe 5g - wifi connection issue
(Topic created on: 09-03-2022 06:19 AM)
Santoshrawat
Beginner Level 3
It has been over 1 month now using s21 fe 5g.
The device wont search for 5ghz wifi connection , it only shows 2.4ghz speed
Its embarrassing to see such flaws on a 50k premium device, that too when device has 5g in it name and a selling feature
Then every time i turn off wifi from top swipe and try to turn on again. Even though the toggle sign is active , it wont connect to wifi automatically , even though its password are set.
I am tried of going into settings -- connections , clicking and then getting it to work
Very Very embarrassing with such small thing not working and making me regret ... why i went for this s21 fe 5g
5 Comments
0353
Wifi not working 5g
cs_member8
Dear Samsung Customer,
Go to Settings
Select General management
Select Reset
Select Reset network settings
Select Reset settings
Select Reset to confirm
You'll need to register your Wi-Fi again
Go to Settings
Select Connections
Select Wi-Fi
Select the Wi-Fi network you were connected to
Re-enter the password
Select Connect
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Thank you for writing to us.
Samsung Customer Support.
Members_T7NzaQn
Exactly same issue here for me as well.. S21FE5G
Members_T7NzaQn
I had the same issue and I had the same impression about the device.. I found out that it has something to do with the dynamic IP allocation of the router.. Try reconfiguring your broadband router and changing the mode of distribution if you are using a repeater/extender. Hope the issue should get resolved with this.. Not bailing out the device or firmware, but my issue is resolved for now.. Thank you
2025 same issue still not fixed on s21fe
