3 weeks ago in
Galaxy S- Mark as New
3 weeks ago in
3 weeks ago in
3 weeks ago in
Galaxy SDear Samsung Member,
As per your concern, we would request you to kindly perform the following steps to resolve your issue. However, we are taking your valuable feedback regarding this.
Remove the screen protectors and cover from the device once and check the issue after restarting the device.
Press the power and volume down keys simultaneously for a few seconds.
Check space availability: Settings > Device Care >Storage.
Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
Note: To delete files or uninstall apps you no longer use, select a category under USER DATA. Then, tick items to select and tap DELETE or UNINSTALL.
Clear cache memory of a particular application: Settings> Apps> Now pick the app that you like to clear off the cache memory> Storage> Clear Cache.
Uninstall and reinstall the app:
1-Please ensure a stable Wi-Fi connection to your mobile. Downloading via mobile networks may result in additional charges.
2-Please ensure enough storage space in your device.
3-Please ensure your device has sufficient battery for updating software.
Some preinstalled apps cannot be uninstalled. Tap App info, tap More options, and then tap Uninstall updates. Or, tap Disable if you do not plan on using the app.
Keep your apps updated: Play Store apps: Open the Play Store, tap, and then tap your profile picture. Tap My apps & games. From here, you can either tap Update next to individual apps or tap Update All to install all available updates.
Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
Keep your app updated: Tap on Google Play Store app or Galaxy Store> Manage apps & device> Apps available to update> If you want to update apps individually, tap See details and then tap the Update button next to the app you would like to update.
3 weeks ago in
