S21 Fe has battery issues
(Topic created on: 09-02-2023 12:22 PM)
samz2
Beginner Level 4
It's barely been 6 months since I've brought this phone and I'm experiencing battery drain on standby mode and also less usage time. I even got the mother board replaced and also the battery was checked and now the service centre executives claim it may be a software issue and a lot of S21 FE devices are experiencing the same issue. I've spent a lot of money and this is just infuriating. Samsung do something
17 Comments
aviash77
Worst mobile so far used battery 🔋 drain, lag in game , lag in UI , can't see display in direct sunlight
rajhassan31
Set in adaptive mode, then you get clear visibility
aviash77
Already in adaptive mode but still can't see display in direct sunlight not only this mobile even Samsung s20 fe 5G SD 865 my friend is using also can't see in direct sunlight
rajhassan31
I too use in direct sunlight, till now no problem
aviash77
What is the Peak temperature at your place here at 35 temperature 🌡🔥 unable to see display
MohammadAquib
Same with me s21 fe problems
cs_member8
Dear Samsung Member,
We acknowledge your query. Please visit this mentioned link and follow the steps to resolve the battery drain issue
https://www.samsung.com/in/support/mobile-devices/what-to-do-if-the-battery-of-my-new-phone-seems-to...
In case the issue still occurs. Please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link:
https://www.samsung.com/in/support/service-center/
adeebkkhan
S21 fe bakwas phone hai koi lena mat battery drain hoti hai jaldi aur phone heat hota hai bohot
