S21 FE Serious Battery Draining
(Topic created on: 04-06-2023 12:43 AM)
Aakash123
It has been only 15 days i purchased this S21 FE 256 GB Varienty.
Max i have got SOT of 3hr25mins. Today it broke all the recode. With 60 hz, 5G Jio, not a heavey user. Got only 2hr2mins
Also i went to Samsung service center, that lady told me its normal with S21 fe. As the software is not that optimised. But SOT of less than 3hrs is not expected from the high mid range phone.
Pls tell the solution, if you guys have
15 Comments
parthasamsung
Turn on refresh rate to 60 Hz from 120 Hz. You will get more that 6 hours SOT.
Aakash123
brother already using 60 hz from day 1
parthasamsung
Have you installed latest one ui 5.1. If yes then please reset the system settings only and restart your phone then,that will work.
Aakash123
thanks for the reply
i received 5.1 out of box it was pre updated, what should i do now?
Sáyân15
Did we payed the huge amount to limit all the features & use the device with everything turned off?
Then why didn't you buyed a mid-range device instead of buying a flagship🙄
parthasamsung
Charge your phone to 100% and then check SOT
satdidoS24
No use to share issue because samsung won't fix this
Remis
I'm getting minimum 5.5~6hrs SOT since 1 year on my S21 FE, i use 120hz.
But 5.1 update has many bugs i think it will be fixed in the next updateScreenshot_20230406_102840_Device care.jpg
parthasamsung
Have you made any changes in your settings?
