S21 5G ui7 problem
(Topic created on: Sunday)
fxrasel
S21 5G ui7 problem
4 Comments
BiRdMaN
You will get a stable version in the month of may, as mentioned by them, and ShAMeSUNG never says the exact date, so be patient
If my reply answered your query, please tap 3 vertical dots to the right of my reply and click on Accept Solution. Thanks 😊
goodthings
You will be get One UI 7.0 stable version update may be in this quarter. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
We request you kindly share the log file and elaborate on your concern in detail. Also, share video clips and images for better understanding. This will help us to investigate further and resolve the issue.
Path share log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.)
