S20fe 5g - Quick Battery drain after latest Update
(Topic created on: 01-03-2025 10:38 AM)
KumarS20_FE11
S20fe 5g.
I generally have the battery auto cutoff at 85% charge.
After the latest and last update, I observed that the batteis draining very fast.
Even when the phone is not in use. I hv disabled wifi, mob Data, GPS, bluetooth even then battery seems to be used.
If I'm outside on mobile data, slight use if phone will also hv considerable impact on the battery?
What's the solution for this?
4 Comments
Wodehouse
The Samsung S20 FE 5G's battery drain issue after the latest update is concerning, especially since you've taken steps to conserve battery life by limiting charging to 85%.
Considering you've disabled WiFi, mobile data, GPS, and Bluetooth, the battery drain suggests that there might be an internal process or app causing the issue. Here are some potential causes and troubleshooting steps:
Potential Causes
1. *Malfunctioning app*: An app might be running in the background and consuming battery power.
2. *System process*: A system process or service might be malfunctioning, causing excessive battery drain.
3. *Update-related bug*: The latest update might have introduced a bug that's affecting battery life.
Troubleshooting Steps
1. *Boot in Safe Mode*: Restart your phone in Safe Mode to disable third-party apps. If the battery drain issue persists, it might indicate a system-related problem.
2. *Check for rogue apps*: Use the Device Care feature to identify apps consuming excessive battery power. Go to Settings > Battery and device care > Battery > Battery usage.
3. *Disable unnecessary system services*: Some system services might be running unnecessarily. Go to Settings > Connections > More connection settings > Disable unused services.
4. *Reset Settings*: If none of the above steps resolve the issue, try resetting your phone's settings to their default values. Go to Settings > General management > Reset > Reset settings.
5. *Contact Samsung Support*: If the issue persists, reach out to Samsung support for further assistance. They may be able to provide additional troubleshooting steps or repair options.
Additional Tips
1. *Monitor battery usage*: Use the built-in battery usage tool to track which apps and services are consuming the most battery power.
2. *Adjust battery settings*: Explore the battery settings to see if there are any options that can help reduce battery drain.
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
KumarS20_FE11
Thank you.. I've been thinking of narrowing down to the app which might be consuming more battery but dint know how to do that.. thanks for sharing that info..
I'll also check all the stuff u mentioned and will get back Herr.
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for resolves this issue. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
