10-23-2023 06:07 PM in
Galaxy SHi,
My S20 FE is not accepting correct PIN while unlocking and I'm completely locked out. I have been using the same PIN for about 2 years, and I haven't changed it recently since I always use fingerprint to unlock. Recently I updated my device and unlocked using the same PIN after restart but now it is not accepting.
I'm bummed to see this kind of glitch on Samsung Device, atleast there should be Forgot Password and login with Samsung ID or Google ID to recover.
I tried Find my device to unlock the device, but it seems that remote unlock is not turned on, on my device.
I wiped the Cache partition, restarted and tried the PIN but still didn't work.
I have a year of Photos and Videos stored in that device, don't want to Factory data reset it.
Please help me with this issue if anyone had faced similar issue.
- Tags:
- s20fe5g
- « Previous
- 1
- 2
- Next »
07-05-2025 05:15 PM in
Galaxy Swere you able to unlock your device without factory reset? because apparently I'm going thru the same issue after the recent android 16 update on my S24
- « Previous
- 1
- 2
- Next »
