S20 ultra focus issue!! Help!!
(Topic created on: 12-06-2021 05:05 PM)
abhisek1982
I am suddenly having focus issue on main camera! It can't focus at all.
Wide Angle & zoom camera working fine. How to solve the issue! Please help!
7 Comments
४UNKNOWN४
Call SAMSUNG TOLL FREE NO 180057267864 for service (pickup & drop) or go service center...
Sid_Karna
Please try it in pro mode, so that we can make sure it's not a hardware issue.
abhisek1982
Pro mode having same focus issue
Abid2020
Clear data of camera.
And test tof 4th camera
Dial: *#0*# test tof camera
Tof camera helps to focus.
cs-member13
Expert Level 4
Dear Samsung member,
Thank you for sharing your concern. We acknowledge your query and apologize for the same. We apologize for the inconvenience you are facing And please follow the easy troubleshooting steps which might help to solve the issue.
Check the physical condition of your camera lens.
1. Broken camera lens.
2. Scratchy camera lens.
Please check there is no laminated or tempered glass pasted on the camera.
Use a microfiber cloth or a cleaning wipe. Gently remove the fingerprint, dirt, and dust from the camera lens.
If the issue has not been resolved then Reset camera settings
Please follow the below steps:
Step1: From the home screen tap on Camera.
Step2: Tap on Settings.
Step3: Scroll up and tap on Reset settings.
Step4: Tap on Reset.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback >Ask questions).
Jeffrey diab
I am facing the same problem with my s20 ultra
Can someone help
SJ_9909
Having the same issue.
The only fix I have found is to shake the device to get the focus. But you have to do it everytime you want to click a picture.
Does anyone know if this is a hardware issue or a software issue???
