S20 plus heating issues with camera
(Topic created on: 06-10-2020 05:54 PM)
justSingh
the Exynos 990 S20+ gets hot when using the camera for just over a minute. Very poor standby time for a4,500mah battery capacity. Camera is a dullperformer as well. Easily blurred shots with slight movement. After this new update on June 1st or 2nd ate6   phone just heat up upto 40°c just with in a minute  and above when I start recording videos .
Its like we just waste 73k to 78k  for a peice of hand warmer
justSingh
yaa I am also i am using Samsung mobile since they launched S2 9100
then further S4, S7, S8, S9 and now S20 but this mobile just force me to step back to s9 or s10 even s7 edge was also fantastic device for games and camera i never face this type of problem ever . Think how you would feel if your phone heats up in 1 minute as soon as opening the camera application , while you did even use it .
AquilsS20
Clear data for camera app.. always turn off auto focus, tracking auto focus.. and try.. this may help.
justSingh
Not applicable
The s9, s10 and the note 9 are facing the green tint issue man, There is no escape.😓
justSingh
I am not only one facing it .there are some other users have same issues 😒
but I know it just start heating after this new update in June 1st totally bugs before that it was smooth and cool
shahinahammed
I am facing a huge problem.. With my screen.. Black crushing from last 5 months, after updating to Android 10, am still waitting for the update. Hope your also fix soon
justSingh
hope it should fix it .
shahinahammed
Why I am not changing is. Its fast.. Even my s7 is also same
justSingh
go to settings
then
go to device care or device management
then click on battery
then click on (•••) top left corner
then find the (fast charging) make sure it is on .
try it . hope it should be fine
shahinahammed
I mean phone is fast.. Not charging
