S20 fe battery drainage issue and hitting issues.
(Topic created on: 05-11-2024 04:21 PM)
Gautambhut12
2 Comments
cs_member10
Dear Samsung Member,
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
In case the issue still occurs, please register your concern in the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
PirahnaTrout
Are you facing this after the update?
