08-20-2020 08:47 PM in
Galaxy S- « Previous
- 1
- 2
- Next »
08-21-2020 12:32 AM in
Galaxy Sif dis prblm was mentioned on the box i wld hv not
08-21-2020 06:36 PM in
Galaxy S- Mark as New
08-22-2020 04:36 PM in
Galaxy SDear Samsung Member,
Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
08-27-2020 08:54 PM in
Galaxy SIt's because of Firmware Problem from Past firmware Updates from Samsung ! Wait for Proper Bug Solving Update from Samsung !
Till Then Follow Below Steps
1) Turn ON Reduce Animation Option
2) Uninstall/Disable Unwanted Apps ( Briefing, S Internet, Google Play Music, Google TV and Movies, One Drive, SmartThings, Wearables, Unused Good Lock Modules ....)
3) Disable Game Launcher
4) Turn off Auto Brightness
5) Use Google Apps in Default Factory Versions
6) Clear Memory in Device Care twice an hour
7) Disable Auto Sync (Turn On When Needed)
😎 Use Device in Medium Power Saving Mode
9) Mobile Data and Battery Restrictions for all apps by Click App Info ( Long Press An App) (MUST)
10) Put All Apps In Sleeping Mode
11) Clear Recent Apps
Just Make Sure that don't rush More apps while Using Mobile !
I Followed Above Steps, Restart Problem Solved 👍
If Solved, Accept this Comment as Solution by Clicking 3 dots !
08-28-2020 12:05 AM in
09-09-2020 11:46 AM in
- 1
- 2
- Next »
