[S20+] How to enable edge lighting when receiving an incoming call
(Topic created on: 06-14-2021 08:27 PM)
Vis Gopan
Earlier during my days of S8, I always liked the edge lights running around when the phone is flipped down on a flat surface.
On my s20+ within the long list of missing features that has been degraded when generations evolve😪, i have been missing the edge lighting when receiving an incoming call.
Is there any way to enable it. I somehow found the way to enable it for messages and notifications under brief pop-up. But not working for calls when phone flipped down. Can someone provide some way.
S8 edge lighting during incoming call.
8 Comments
Vicky_A52
That is edge lighting plus we get this feature in 3.5 or 4.0
Now also possible..only difference is you have to turn your device either side..I am regularly using it
Vis Gopan
Are you using on one ui 3.1?
No 2.5
Vis Gopan
Yes, hope you are referring to s20+ and it is running on 3.1. I used to have these earlier, but not now.
Oh is it ? Sad then
Darkvader12
Not possible
