S20 FE 5G battery backup problem
(Topic created on: 08-07-2024 07:18 AM)
TechyKamal
Accubattery is showing that my phone's battery health is 77%. Should I replace my battery? I am already getting very low backup. And if anyone has replaced the battery, what's the approximate cost?
9 Comments
Sameer
Check the same in Samsung Members in DIAGNOSTICS..don't rely on 3rd party app
TechyKamal
In samsung members app, battery life is showing NORMAL instead of GOOD. It's showing normal since almost a year.
Zain1999
Batteries have a life of 3-4 years in ideal conditions. There are some factors you can change to lead your device to better battery health, here are the following:
• Use battery saving mode,
• Turn off location, mobile data when not in use,
• Use battery protection that will limit battery to 85% which will increase the longevity of the battery as conapired to charging it to 100%,
• See which apps utilize the most battery are disable background usages usually it is Google play services.
Other factors to keep in mind:
• If you dropped your phone, your battery can be negative affected and there is a very small chance of malfunction by consuming more battery.
• Using phone outside 15°-35°C isn't optimal for your battery.
If this answer was helpful, click on the three dots and mark this comment as a solution. Thank you for reading.
TechyKamal
When even 100% charge is not giving basic battery life, why will I limit it to 85% now!
SUSANTA3
Please don't use third party app. BTW https://youtu.be/RwJP2C8jf-o?si=cCi0-rzgWoRj7xjV
You can try these
TechyKamal
I don't use this app regularly. I downloaded it just yesterday
Reacher03
Use dark mode, switch 120 to 60 HZ, switch 5G to 4G, turn off AOD(Always On Display)
cs_member10
Dear Samsung Member,
As per your concern, we want to inform you that we does not recommends to use any third party application for check the battery health of Samsung device, however, you can also check the battery health using the Samsung Members app, Battery Status(Battery Status (Battery life + Battery Capacity)). if it shows bad or weak then you have to visit the service center, else it is showing normal there is no need to worry.
Moreover, kindly perform the following steps to resolve your battery draining issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
Selvawtu
The approximate cost will be 2700 inr
