S20 FE 5G -Front Camera quality is very bad when compared to Rear Camera
(Topic created on: 01-18-2022 08:21 AM)
Saravana1307
The picture quality is very different on 32MP front camera,focus is not that great as well as quality.
I'm not sure if I am missing any setting,or it's the camera itself.
Kindly try to
 fix this guys.
Back Camera quality
Selfie camera quality
10 Comments
Sid_Karna
Front camera is supposed to be of lesser quality than the rear one. It's normal and is like that in all devices including apple.
However you can get the best out of it by turning off the beauty mode, selecting 32 mp option all the time etc.
Pls accept the solution by clicking on the 3 dots on top of my comment,if you found this helpful.
Saravana1307
I'm new to samsung earlier I was IPhone user.so my expectation was the 32MP front camera would be good.
Sid_Karna
However reviewers like techwiser say that the Samsung selfie cam is better than iPhone's. See his latest comparison bw iphone 13 and pixel 6 where he says this.
Saravana1307
I'm not sure the fact behind it, or I am worried if I am missing any cam settings.
Plus...the focus only focusses on tapped area...for example in 1st pic upper portion of penhandler is more clearer than its lower zone
Dont know why
BVikram
I don't know which model you referring. I am assuming it's S20FE. Front is a non premium pixel bining gimmick camera. Where as back camera is a premium one directly picked from S21 line. But for Fan edition they hesitate to take Front camera.
Saravana1307
Thanks for the response. So I guess no way samsung would upgrade this front camera.
cs-member13
Expert Level 4
Dear Samsung member,
Thank you for sharing your concern. We acknowledge your query and apologize for the same. We apologize for the inconvenience you are facing And please follow the easy troubleshooting steps which might help to solve the issue.
Check the physical condition of your camera lens.
1. Broken camera lens.
2. Scratchy camera lens.
Please check there is no laminated or tempered glass pasted on the camera.
Use a microfiber cloth or a cleaning wipe. Gently remove the fingerprint, dirt, and dust from the camera lens.
If the issue has not been resolved then Reset camera settings
Please follow the below steps:
Step1: From the home screen tap on Camera.
Step2: Tap on Settings.
Step3: Scroll up and tap on Reset settings.
Step4: Tap on Reset.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback >Ask questions).
SantiLeo
Yes...i bought a s20fe 5g 15 days ago, the front cameraIt's TERRIBLE. High megapixel and detail but pictures are way overexposed and your skin is very light and washed out. You look like a fkin ghost! Worst part about this phone.
Being an "s" range equipment and with the time it has been on the market, they should release an update that solves the problem of the very white tones and the dynamic contrast of the front camera.
It is embarrassing that the A52 has better colors and contrast management in the front camera than the s20fe costing more money and being of the highest range of samsung.
A scam to the buyer.
