S10 Plus display flickering when charging & Green tint issue
(Topic created on: 11-02-2021 11:18 AM)
bkgm
Hi Guys please any one give solutions...I dropped My S10+...But display not damaged...but Screen flickering & green dint issues coming....how to solve this issues...Please Give solutions bros....
8 Comments
diweshkumar
May you problem can be solved if you restart your phone
diweshkumar
please follow me and accept my solution
Better visit service center and get it checked once
bkgm
Already I Visit bro they told change the display
Mnkpz
I think display is not brocken but damaged in internal part
if serveice center was speaking for change display then no other solusation
MLD
First of all this an issue with the display itself not with the lens, i too have Note 10 plus which had a similar issue ( Green Tint ) after a year of purchase, this becomes common in samsung flagships especially with exynos processor. Dont expect samsung will solve this with software update, if you contact the service center , they will ask u to change the display. All samsung flagships had the bug in their Dark Mode, if you use ur device in dark mode for prolonged time then definitely u will come across this green tint bug.
Prefer light mode theme and avoid exynos in future.
Dear Samsung Member,
We acknowledge your query and apologize for the same. We request you to kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
DannyDJ
This is not because u dropped ur phone this issue persists on all S series devices my s20 ultra was 1 year old right after my warrenty ended this issue started.... i been using samsung for nearly 6years and changed around 8 S series gadgets..... there is no solution to this if u take the phone service center they'll say display gone u have to change for me they have asked around 20+k... only solution is change the phone i moved to apple now....
