Resolved! Solved
S10 Plus - MYFILES does not work - crashed "stops working" every time.
(Topic created on: 03-02-2023 01:54 AM)
amazoncharlie2016
Just got the S10+, did the updates etc., every time I go to MYFILES and select any of the options (documents, downloads etc.) it stops and says app has stopped.  Have cleared data, cache, done everything I can think of - sometimes it doesn't even give me an error message, just takes me back to my home screen.  I do NOT want to reset the darned thing!  Only had it one day - if it doesn't work, will return it.... don't want to as the camera is WAY better than my A32 5G phone.....
NOOB_1ST_ACC
Reinstall updates of my files
If found useful/on point then tap on 3 dots and accept as solution.
4 Comments
NOOB_1ST_ACC
WOW!  YOU ARE JUST A GENIUS THANK YOU!!!  I went to the google play store, looked up the Samsung version of MYFILES, uninstalled updates, reinstalled updates and it works PERFECTLY!  THANK YOU THANK YOU!
NOOB_1ST_ACC
You are always welcome
NOOB_1ST_ACC
Thanks
