08-15-2024 07:33 PM in
Galaxy SSolved! Go to Solution.
08-15-2024 08:18 PM in
Galaxy S- Mark as New
08-15-2024 08:05 PM in
08-15-2024 08:09 PM in
08-15-2024 08:17 PM in
08-15-2024 08:19 PM in
08-16-2024 09:59 AM in
Galaxy SDear Samsung Member,
As per your concern, we want to inform you that when initially using the device, battery consumption may be rapid due to learning battery usage patterns and application of performance optimization. It will stabilize after a certain period, but if still facing heat and drain issues, kindly perform the following steps to resolve your issue.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
Galaxy device quick share not working issue: Quick Share is a new sharing service for sending photos, videos, and files with your friends and family is available on the previous Galaxy series when upgraded to Android 10. File sharing has never been so easy on a Galaxy.
Before you try the recommendations below, be sure to check if your device's software and related apps are updated to the latest version. To update your mobile device's software, follow these steps:
Quick Share will let you share images, videos, and files instantly with your friends. You can share files with up to 5 people simultaneously without the need of pairing devices.
Step 1. First, make sure the Quick Share feature is turned on for both phones. On the other device, open the notification panel, swipe downwards, and then tap Quick Share to activate it. It will be blue when it's activated.
If the Quick Share icon does not appear in your Quick settings panel, you may need to add it.
Step 2. Launch the Gallery app and select an image. Tap the Share button and select a device to transfer the image. Accept the file transfer request on the other device.
Step 3. If you’re having trouble connecting to another device, swipe down from the top of your screen to open Quick Settings, and then touch and hold the Quick Share icon. Tap the switch next to "Show my position to others" to let nearby devices see your device when they are using Quick Share. This option will only show if Quick Share is enabled.
The "Show my position to others" option is only available on select models.
Tips about using Quick Share:
If you are unable to locate your device ensure you have enabled your phone or tablet visibility. To enable this setting head into your Settings > Connections > toggle on Phone Visibility. You can share files with up to 5 devices at once.
· Make sure the other person's screen is on. You may incur additional charges when sharing files via the mobile network.
Devices based on Android Q OS will support this Quick Share feature and available targets may differ by device model.
· The receiving device must support Wi-Fi directly. The receiving device’s screen is on.
· Wi-Fi must be turned on.
· You can send up to 1GB at one time and a maximum of 2GB per day.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
08-18-2024 05:03 PM in
