11-15-2024 05:33 PM (Last edited 11-16-2024 11:00 AM ) in
Galaxy S- Mark as New
11-15-2024 06:27 PM (Last edited 11-15-2024 06:27 PM ) in
Galaxy SAnd what is your issue with NFC?
11-15-2024 06:31 PM in
Galaxy SAnd i have a small device given by my work for NFC whenever i tap to login nothing happens and i have to use USB signon everytime
11-15-2024 08:16 PM in
Galaxy SWhere do you tap the NFC thingy? On the NFC reader which is beside the cameras or somewhere else?
11-15-2024 08:18 PM in
Galaxy SI tried the NFC thingy almost every where front and back but no luck, I'm guessing some setting is blocking this from happening
11-18-2024 03:13 PM in
Galaxy SDear Samsung Member,
As per your query, we would request you to please check if other device supports wireless charging and that you device is always charged beyond the battery limit of wireless power sharing.
● To check battery limit of wireless power sharing please follow the path:
Path: Settings>Device care>Battery>Wireless power sharing>Battery limit.
● For NFC: Please check if NFC is enabled in your device:
Path: Settings>Connections>NFC and contact less payments.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
