Regd. Mobile data connectivity issue
(Topic created on: 01-02-2022 02:59 PM)
satio
Just now I cleared wipe cache partition clear through recovery mode..from then on mobile data network bit improved
cs-member13
Expert Level 4
Dear Samsung Member,
We apologize for the inconvenience you are facing. We understand your concern and will help you resolve this. Kindly follow the below steps to resolve your issue:
Check device network mode settings
Please follow the below steps.
Step1: Navigate to apps screen and tap on Settings.
Step2: Tap on Connections.
Step3: Tap on Mobile networks.
Step4: Tap on network mode SIM1 or SIM2.
Step5: Select network mode.
Note: We recommend to set device network mode as LTE/3G/2G (auto connect) mode.
Check network operator settings
Kindly set device network operator as "Automatically".
Step4: Tap on Network operators.
Step5: Select automatically.
Note: We recommend to set device network operators as LTE/3G/2G (auto connect) mode.
Step6: Tap on OK.
Step7: Registered on network.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
