Regarding battery drain and overheating issue after July SW update
(Topic created on: 07-06-2025 08:27 AM)
binnyjoseph70
Phone(samsung galaxy S23) battery fast draining issue, slow charging and overheating after recent update
4 Comments
BiRdMaN
It is a BUG send an error report along with log files to customer support through this members app and Samsung will fix it in the next update. To do that follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful please Accept it as a solution Thank you 😊
goodthings
Kindly complaint to Samsung customer care support through Samsung Members app as error report also send log files along with this error report for this issue and wait for next update maybe fix it by Samsung team soon. If you like please accept as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
cs_member10
Dear Samsung Member,
As you are facing multiple issues with your device, we kindly ask you to share the log file with us. Additionally, if you have any video clips or images that illustrate the problem, it would greatly enhance our understanding.
Path: Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
