Regarding Battery life of S23 Fe
(Topic created on: 11-21-2023 02:56 PM)
DrAtharvaSharma
I think battery of my S23fe is Draining fast. In a regular usage I have to charge my mobile two times a day i.e every 8 hours. Because I don't use my mobile at night very often. Just a 10 min or 15 min after bed.
Is it so or Just I am thinking like this.
And also I optimise my battery time to time
9 Comments
_debajyoti_
Same problem with S21FE 888
AtG1985
No such problems with s21 fe 888
one_daredevil
And the same; fast 🔋 battery drainage issues with samsung galaxy a53 5g device , Exynos Processor experience is very bad 👎
AtG1985
Samriddhap
S 21 fe exynos same problems, battery dropping very fast
NicknameFE
I am getting 2 days backup with normal usage. That also after limiting max. Charging to 85%. Also start charging when it goes down in the range 15 to 20%.
That means effective 70% battery is giving me nearly 2 days backup.
Or 1 and half days assured backup.
JermainKho
Beginner Level 5
Thats good, ive read that charging up to 70% even lengthens the battery life than 80%
cs_member10
Dear Samsung Member,
As per your concern, we would request you to kindly perform the following steps by a given link to resolve your issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can check the device in safe mode and for the same mode you can tap on the given link. https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
In case the issue still occurs please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Harifism
Beginner Level 4
Yes. I'm also experiencing the same problem. Battery drain very fast even if there is no screen on time. 8 hours is maximum for my phone to turn off without doing anything while my 2 year old OnePlus still gives me 1 day of battery life and idle drain is very very low on that phone. S23 fe is very disappointing in terms of battery life!
