Regarding 5g and hotspot issue
(Topic created on: 05-04-2025 09:14 PM)
shirish_jain1008
Beginner Level 4
Been using my s23ultra 5months noticing jio5g and mobile hotspot unstable connection issue any solution for this or anyone else facing this issue
3 Comments
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
1. 5G in your Galaxy device: https://www.samsung.com/in/support/mobile-devices/how-to-use-5g-on-your-galaxy-phone/
2. Galaxy device hotspot issue: ● Disable the data saver: Path: Settings > Connections >Data usage > Data saver > Disable data saver (if enabled).
● Reset network settings: Path: Settings > General Management > Reset > Reset network settings.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
● Update device software (If available): Settings > Software update > Download and install > Checking for software update > Software update available > Download > Downloading updates > Install now.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
