Quick panel help
(Topic created on: 05-24-2026 01:28 AM)
g4lyf
After the latest one ui 8.5 update on my Galaxy S23+ the quick panel looks like this
How do I reduce the icons per row and increase spacing?
5 Comments
Asif4873
Install Good Lock app and then add QuickStar. In QuickStar advanced setting you can find button spacing
g4lyf
Thanks a lot, I'll check it out
linsoncv
I am not sure why it looks like that. You can completely change it by clicking on the edit button
g4lyf
I tried, but I'm only able to add or remove icons but not adjust the look
cs_member10
Dear Samsung Member,
As per your query, we would like to inform you that In One UI 8.5, Quick panel controls can be edited individually rather than in groups. You can use the edit function on the Quick panel to arrange them in your preferred layout. Place frequently used controls at the top for faster access without additional scrolling. This improves overall usability and screen readability.
How to remove, move, or resize Quick panel controls
Step 1. Swipe down from the top right corner of the screen to open the Quick panel.
Step 2. Tap the Edit icon.
Step 3. Tap the Remove icon at the top left of a control to delete it.
Step 4. Touch and hold a control, then drag it to the desired position.
Step 5. Drag the right edge of a control to resize it.
You can also change its orientation.
Note: Control resizing and orientation options may vary depending on the control.
