Quick Battery Drain
(Topic created on: 05-26-2023 10:11 PM)
ashu10sh_singh
I've had a serious problem with rapid battery drain ever since I installed the most recent update (G781BXXS5HWD4/ G781BODM5HWCH / G781BXXU5HWCH, Security Patch 1 May 2023) on my device (S20 FE 5G). The battery life, which was formerly dependable, has drastically decreased, and I now need to recharge throughout the day. I can't use my device for extended periods of time without being connected to a power source, which is really aggravating. My work has been significantly impacted, and there have been a lot of unneeded disruptions as a result of this abrupt and extreme fall in battery efficiency. I'm hoping that a fix or patch will be made available very soon to address this problem and return the battery performance to what it was.
5 Comments
techcreater
Even I am facing the same problem of battery drainage I am using Samsung galaxy s22 Plus..
And I have to connect my phone to the power source more often... And their charging technology is slow as well and it take almost an hour to charge every time I can exit to the power source... Hope Samsung will take this matter seriously and solve this in the upcoming updates
AnandSaheb
For the time being, use power saving mode to help get a better expected SOT. You can use modes to use Power Saving more smartly. Personally, I feel S-Series of Samsung gives a lower SOT than it's mid-ranger.
if you not done yet then do some settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
FOR ANDROID 11;
A. DEVICE CARE > Battery>Background Uses Limit > Put Unused App to Sleep
B. Device care>click on 3dot at top right corner>automation>adaptive power saving
C. Device Care > Battery> More Battery Settings>Adaptive Battery
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info(ibutton)>> go to these 3 options below on by one
6. Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will shared data to show recommendation and suggestion which also cause battery drain
7. Go to settings > account and backup> Manage account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on weather settings (icon)> change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
(Ehsank)
Mr_Gautam
Then what's the point of buying a flagship phone if we have to turn off everything?? It's a huge and irritating problem which Samsung should solve with updates.
cs_member10
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. And please follow the easy troubleshooting steps which might help to solve the issue.
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Warm regard,
