drviper
05-02-2025 11:52 AM in
1. Unnecessary scroll bar even if there is only one page in app drawer. This interrupts closing app drawer by swipe down.
2. Some buttons which are not necessary for me cannot be hidden in quick panel in together mode. Kindly provide option to hide all the below buttons.
3. After taking screenshot, it takes more time for the edit options to appear than OneUI 6.
4. Tapping on brightness slider and volume slider in quick panel behaviors are different.
Brightness slider tap should work similar to volume. When tapping brightness slider, it increases brightness to that level but it should change only when tap and slide instead of just tap.
Kindly like the post to show your support so that it reaches developer team.
7 Comments
Thekkverma
05-02-2025 01:17 PM in
These issues were in first beta. These continued in final update even after reporting them. Apart from these, if you long press notification then there will be overlap of text on notification. Lockscreen editing options have been removed. There is overlap between fingreprint and notifications on lockscreen
drviper
05-05-2025 01:19 PM in
I am able to edit lockscreen in my S23 Ultra. (Touch and hold lockscreen)
Thekkverma
05-05-2025 02:05 PM in
can you share a pic of it
drviper
05-05-2025 03:02 PM in
Both of these options can be used to edit lockscreen. You can also try LockStar from Goodlock for extra customization.
Thekkverma
05-05-2025 03:03 PM in
i was not talking about this option. Earlier when you used to click edit lockscreen, you use to get effects option on edit lockscreen page. But now it is no longer visible
Thekkverma
05-05-2025 03:07 PM in
i was talking about the effect option at the bottom
drviper
05-06-2025 02:11 PM in
You mean this one? It is visible for me.
