Problem
(Topic created on: 06-27-2025 09:52 PM)
rohanrouth
After ui 7 update my s23 fe display start lagging
It's happening with everyone or my phone have this issue only
4 Comments
goodthings
goodthings
Your's most welcome to here.
BiRdMaN
It is a BUG send an error report along with log files to customer support through this members app and Samsung will fix it in the next update. To do that follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful please Accept it as a solution Thank you 😊
cs_member10
Dear Samsung Member,
● Remove the screen protectors and cover from the device once and check the issue after restarting the device.
Path: Press the power and volume down keys simultaneously for a few seconds.
● Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
● The clear cache memory of a particular application:
Settings > Apps > Now pick the app you like to clear off the cache memory > Storage > Clear Cache.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
● Enable/ Disable sensitivity touch: Settings> Display >Touch sensitivity.
● Check space availability: Settings > Device Care >Storage.
● Keep your app updated: Tap on Google Play Store app or Galaxy Store> Manage apps & device> Apps available to update> If you want to update apps individually, tap See details and then tap the Update button next to the app you would like to update.
