Resolved! Solved
Problem with buds codec on s24
(Topic created on: 10-05-2025 10:07 PM)
vanshjay
 I have enabled the lhdc support but there is no option to enable it in my bluetooth setting .
 Any help?
Chinmay96
As of now, Samsung phones do NOT support LHDC (Low‑Latency High-Definition Codec)
3 Comments
Chinmay96
cs_member10
Dear Samsung Member,
As per your concern, we want to inform you that you can check the Bluetooth Audio Code that supports your device by following these steps:
Path: Settings app > Developer settings > Bluetooth Audio Codes. If a particular codec is greyed out, it means it is not supported by your phone or headset.
If you have any other concerns regarding Samsung products, kindly feel free to get in touch with us.
vanshjay
But why samsung doesnt support lhdc whereas all smaller companies do.
