Problem regarding software issue
(Topic created on: 05-09-2025 07:17 PM)
Haris31
I always get this message every time when I restart my phone and I didn't receive one ui 7 I am still stuck in one ui 6 beta I have also tried to downgrade but it didn't help me
6 Comments
sameer0037
Same im s22 user
sameer0037
For me last update received on Oct 2023
Haris31
Yes me too
cs_member8
Dear Samsung Member,
As per your concern, we want to inform you that you can update the software by using Smart Switch. You can open Smart Switch on your Windows PC or Mac, you will see an option to update to a new software version if one is available. kindly perform the following steps to resolve your issue.
Step 1. Connect your device to your computer using the USB cable provided with your device.
Step 2. Open Smart Switch on your PC.
Step 3. If a software update is available, Smart Switch will automatically prompt you to update the software or display an option to update.
Step 4. Tap Update and follow the on-screen instructions to download the necessary files and complete the update process.
Haris31
I didn't get any message that I have a new software
Haris31
Now I too have a screen issue due to this
