Problem in Zoom
(Topic created on: 12-05-2024 01:00 PM)
ARIFIFTEKHARMOZ
After 10x zoom here problem occur with S23 Ultra after done December security updates.
Kindly fix it.
cs_member10
Dear Samsung Member,
We also request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
