Problem facing
(Topic created on: 07-24-2024 02:41 PM)
rohito1
I am experiencing low audio volume from the top speaker of my recently acquired Samsung S23 during phone calls and ringtone alerts. However, the audio functions normally when playing music. The device has been updated to the latest July update. Kindly provide a solution to rectify this problem.
13 Comments
cs_member10
Dear Samsung Member,
Disconnect anything plugged into the headphone jack like, a selfie stick, headphones, Bluetooth, etc.
Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device.
Check device volume settings: Tap on Settings > Sound & vibration>Volume > Drag the volume adjustment bar left or right to increase or decrease the device volume.
To verify, play music and check the music sound. If the sound quality is good, then your speaker is working fine.
Clear Sound Picker data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Picker> Storage> Clear data of Sound Picker.
Clear Sound Alive data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Alive> Storage> Clear data.
Clear Adapt sound data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Adapt Sound> Storage> Clear data.
Reset app preferences: Settings> Apps> Three dots> Reset app preferences> Reset.
rohito1
so I did this thing, but it didn't work. Now, when I pick up my phone, the top speaker doesn't work. But when I put it down, it rings just fine. I think it's a software issue.
Shubhu046
Same with me
rohito1
It not problem
Shubhu046
Then what is it ???
Shubhu046
My top speaker doesnt work for ringtone...but does for media...should i show it to the service center??
rohito1
No I visited
rohito1
They ignore you and your problem 😂
rohito1
But I research and find that it is a part of battery saving
