Problem and more problems
(Topic created on: 04-26-2025 12:47 AM)
abhi_satara
What's this?
Whenever I connect to wifi device restart automatically?
What's this samsung?
Day by day I m hating samsung mobiles.
Now bored n frustrated
4 Comments
NSM001
Send it urgent basis
cs_member10
Dear Samsung Member,
Note: Kindly use genuine Samsung charger.
1.Disable auto restart function, there are two methods to disable auto restart function:
Settings > General management > Reset > Disable Auto restart (if enabled).
If the issue has not been resolved, then follow;
2.If you are facing this issue after installing any new application, then uninstall that application:
Settings > Apps > desired app > Uninstall > OK.
3.If the issue is still not been resolved then, update software:
Go to Settings > Software update > Download and install > Checking for software update > Software update available > Tap on Download > Downloading updates > Tap on Install now
4.If the issue still persists, then reset the settings: Go to Settings > General Management > Tap on Reset > Tap on Reset settings.
5.If the issue is still not been resolved, Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
If the issue still persists,kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send).
goodthings
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
