Problem after one ui 7
(Topic created on: 05-08-2025 12:48 AM)
zahedr
Rotate to landscape mode is note working in one ui 7?
3 Comments
goodthings
Kindly scroll down the notification panel and click on concern icon. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member8
Dear Samsung Member,
As per your concern, we would like to inform you that In the One UI 7, when rotating the home screen to landscape mode, moving app icons and widgets and editing widgets is restricted.
· If you try to execute the editing function in landscape mode, it will be provided as executing after switching the home screen to portrait mode.
· When rotated to landscape mode, the ratio of the width and height of the screen is reversed, so the arrangement is also reversed. (For example, if a 4×6 user rotates horizontally, it is reversed to 6×4). Because of this, the placement on the vertical home screen changes.
· To provide the shape of widgets and the location of app icons and labels in landscape mode similar to that in portrait mode, when rotating to landscape mode, the upper left corner is filled with larger widgets first. Therefore, in some cases, the position of the widget may change.
Samsung Customer Support”
