Problem | Issue
(Topic created on: 11-08-2024 02:36 AM)
Maarann
I can't add my credit card or Debit to samsung pay on my s24 ultra... why?
5 Comments
61i
cs_member10
Dear Samsung Member,
As per your concern, we want to inform you that there are some selective cards that can now be added to your Samsung Wallet. You can check the card information using the details provided below:
Link: https://www.samsung.com/in/samsung-pay/#faqs
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
saireddyy
Some cards won't support
Restrict by banker due to policies
Maarann
But it is working in iPhone 🥲
Jigar11
💟In Hindi... ....
Agar apka debit card ya credit card samsung pay main add nae ho rha Hai....ya decline Ata Hai....or apne pehle card add Kiya Tha or ab nae ho rha Hai...
Solution.....
To ap Google main samsung privacy main login ker k samsung pay ka data ko delete Kar ne ki request dal dizia ...or kuch hi Samay main apka samsung pay ka data clear ho jayega .....uske baad ap Apna debit ya credit card add ker payee ge
Per dayan rakhe is main apka reward or point bhi Chale jayega....
Thanks me later...😄🙂
If you have any questions, feel free to comment and mention me and direct message to my profile
💟 in English.....................
If your debit or credit card is not being added to Samsung Pay, or if it's being declined, or if you were able to add a card before but can't now, here's a solution:
You can log in to Samsung's privacy settings on Google and submit a request to delete your Samsung Pay data. In a short time, your Samsung Pay data will be cleared. After that, you will be able to add your debit or credit card.
But be careful, your rewards and points will also be lost in this process.
You can thanks me later... 😄 🙂
If problem solved....please click on solve
