Resolved! Solved
Power button double click configure
(Topic created on: 09-19-2021 02:53 PM)
Siddify
Is there a way to configure double click of power button to activate "Do Not Distrub" - looking for faster ways to activate DND mode on my Galaxy S21+
Š
Use bixby routines.
You should also install Goodlock& routines +Screenshot_20210919-155955_Bixby Routines_6534.png
7 Comments
Green_Grass
No
Green_Grass
Still there is faster way
Using quick panel
Š
Use bixby routines.
Š
You may have to set one more to turn off DNDclipboard_image_1632051955147_1632051955147.jpg
animeshmodi
How to do it on one ui core?
Š
You might need 3rd party apps. I don't know which.
