Please fix the S23 mobile network signal level issue
(Topic created on: 05-07-2025 01:04 AM)
MathanPRK
Hello Team,
I have a Samsung Galaxy S23. I'm experiencing a mobile network signal level issue. In my home, there is no network for the particular network. It's showing network level is full. If try to call someone. Showing an error saying the network is not registered. Please fix this bug ASAP.
jaimin1210
Do you received any call after that problem
MathanPRK
No. If I go outside. It's working.
jaimin1210
Then it might be glitch, bug etc
Abhijeet226
Which network or SIM card are you using?
MathanPRK
Bsnl
Abhijeet226
Then you need to get a new sim as a replacement from the Bsnl office. It will cost around 50rs, and take a xerox of your aadhaar card.
MathanPRK
The same sim is working as expected in another mobile.
Abhijeet226
Try a different sim in your phone then let me know, what about your other sim if you are using dual sim
goodthings
goodthings
Your's most welcome to here.
