Please fix the S23 mobile network signal level issue
(Topic created on: 05-07-2025 01:04 AM)
MathanPRK
Hello Team,
I have a Samsung Galaxy S23. I'm experiencing a mobile network signal level issue. In my home, there is no network for the particular network. It's showing network level is full. If try to call someone. Showing an error saying the network is not registered. Please fix this bug ASAP.
20 Comments
jaimin1210
Try to remove the sim card once and reinsert it ,it may be dislocated little bit from place .. if still not in setting network operators check the operators if in automatically switch to manual and find one and then click .. ( same as the sim card is of )
MathanPRK
No. It's a bug. If I tried flight mode turn on and off. It's showing correctly. After some time, again, it shows a full signal level.
Yes it's a bug i was also facing that issue on my jio sim but they eventually fixed it for me and now I am not facing that same issue
MathanPRK
How did you fix that? Could you please explain me?
Abhijeet226
That's totally a hardware problem, dude. Replacing the SIM card will fix it for sure.
jaimin1210
But on calling it is getting network not registered true
MathanPRK
It's true. That's a common error when the mobile network is not reachable.
jaimin1210
Have you tried putting esim and then just removed it
MathanPRK
I don't have esim
