01-27-2024 02:26 PM in
Galaxy SHi,
I have recently been experiencing a "feature" with my Samsung Galaxy S20FE 5G that is about to drive me crazy...
Following one of the Android updates earlier this year (I believe), I noticed that my phone automatically switches to "silent" when connected to a bluetooth device (e.g. earbuds or speakers). As long as it is connected, it is possible to take it out of silent mode manually but it goes on silent again .
I have been experiencing this from past 3-4 weeks
The problem is that the phone continues to stay in "silent" even after the bluetooth device is disconnected, and I will hence not notice any incoming calls unless I remember to manually turn the sound on again.
Does anybody have any tips as to what might be causing this, and how to resolve it? (if possible)
01-27-2024 03:38 PM in
Galaxy SNext will be Settings> Connected Devices > Smart Things and check under Life and Routines tab.
01-27-2024 10:06 PM in
Galaxy S- Mark as New
01-28-2024 12:25 PM in
Galaxy SDear Samsung Member,
Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
Note: To delete files or uninstall apps that you do not use anymore, select a category under USER DATA. Then, tick items to select and tap DELETE or UNINSTALL.
The clear cache memory of a particular application:
Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
You can check the device in safe mode and for the safe mode you can tap on the given link. https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
