Overnight battery draining problem
(Topic created on: Saturday)
Arman2830d
I have noticed that my s23fe has overnight battery draining issue.It reduces almost 10-15% in a single night.how can i solve it?
6 Comments
Wodehouse
Expert Level 4
Overnight battery drain can be frustrating, but there are steps you can take to improve it on your Samsung Galaxy S23 FE. Here are some tips:
* Identify Battery-Draining Apps: Check your battery usage statistics to see which apps are consuming the most power while you sleep. You can then take steps to optimize those apps, such as restricting background activity or uninstalling them if they're not essential.
* Enable Power Saving Mode: Your phone's built-in power saving mode can help reduce battery drain by limiting background activity, lowering screen brightness, and restricting certain features.
* Turn Off Features You Don't Need at Night: Features like Bluetooth, Wi-Fi, and GPS can drain your battery even when you're not actively using them. Turn them off before bed to minimize overnight drain.
* Adjust Screen Brightness: Lowering your screen brightness can significantly improve battery life. Set your phone to auto-brightness or manually adjust it to a comfortable level before bed.
* Optimize Background Activity: Background activity can drain your battery even when you're not using your phone. You can restrict background activity for individual apps in your settings.
* Update Software: Ensure your phone is running the latest software version, as updates often include bug fixes and performance improvements that can help with battery life.
Here's an example: Let's say you identify that Facebook is a major battery drain overnight. You can try reducing its background activity or uninstalling it if you don't use it frequently.
By following these tips, you can hopefully reduce overnight battery drain on your Samsung Galaxy S23 FE and wake up with more power in the morning.
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
goodthings
goodthings
Your's most welcome to here.
mnh
Check aap which is consuming battery. And you can also use night mode from routines to save battery
Kunal2
Poor network reception may be the reason. Turn on airplane mode before sleeping.
cs_member10
Dear Samsung Member,
Kindly perform the following steps to resolve your issue by the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
→ Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
→ You can reset your device by following the steps.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
